I only know to create blocks via the ‘Block’ command, or copying existing instances around.
Is it possible to write a script that will let me choose from a list of existing blocks, and then just place an instance to a desired point?
My case is that some instances I need are on layers that are hidden, and should remain hidden for manageability. An even more important case is when I’ve accidentally deleted all instances of a block definition, but it still exists in the block manager from where I’d love to place a new one.
Currently I use the “Export” function as a workaround, but it’s not very practical.
Many thanks for your help.
