I thought that rs.InsertBlock should import a block instance that is allready in the document, but when I do the following, I get the message: does not exist in InstanceDefinitionsTable
import scriptcontext as sc
import Rhino
def blocks():
rs.EnableRedraw(False)
topfwd=rs.FindFile("topfwd.3dm")
centerfwdps=rs.FindFile("centerfwdps.3dm")
centerfwdsb=rs.FindFile("centerfwdsb.3dm")
topcenterps=rs.FindFile("topcenterps.3dm")
topcentersb=rs.FindFile("topcentersb.3dm")
rs.Command("_-Insert File=Yes LinkMode=Embed "+topfwd+" Block 0,0,0 1.0 0.0")
rs.Command("_-Insert File=Yes LinkMode=Embed "+centerfwdps+" Block 0,0,0 1.0 0.0")
rs.Command("_-Insert File=Yes LinkMode=Embed "+centerfwdsb+" Block 0,0,0 1.0 0.0")
rs.Command("_-Insert File=Yes LinkMode=Embed "+topcenterps+" Block 0,0,0 1.0 0.0")
rs.Command("_-Insert File=Yes LinkMode=Embed "+topcentersb+" Block 0,0,0 1.0 0.0")
arrow_blocks=rs.ObjectsByType(4096, select=False)
rs.DeleteObjects(arrow_blocks)
rs.EnableRedraw(True)
point = [10,0,0]
rs.InsertBlock(topfwd,point)
blocks()
ps. when I remove the line rs.DeleteObjects(arrow_blocks) all blocks are inserted
