How does one place many instances of a block?
Hi
V4
I have created a sphere as a block and now need to Insert it many times, one instance per point, and I have many points !
I enter Insert and choose the block name, place it on a point, then all is gone, no ability to place another ,and another.
I type Insert and get the chance of placing one, but not many.
Surely there is a way, like right click on point command, to keep placing instances of the block ?
To have to type Insert each and every time, or even hit enter to get a chance to place another, is impractical, I will be here ages doing that.
Steve
Once it’s a block you can simply copy it.
Cheers
Didnt like to consider that because the copy command is the cause of duplication slowing things up, but as its dealing with a block you say its ok, so I can go with that now.
Many Thanks
Steve
Or array it, normal, polar, along curve on surface etc.
Hi Steve,
Unrelated to the blocks issue, but related to copying things to points:
I have a button to do just that:
  • Select points to copy to
  • get object(s) to copy to the points
  • Select a reference point to be copied from.
The script on the button is this:
! _NoEcho _-Runscript (
Sub main
Pts=rhino.selectedobjects
if isnull(Pts) then Pts=rhino.getobjects("Points ?",1)
obs=rhino.getobjects("Objects ?")
rp=rhino.getpoint("Reference point ?")
rhino.enableredraw vbfalse
for each pt in Pts
  if rhino.ispoint(pt) then
    xyz=rhino.pointcoordinates(pt)
    rhino.unselectallobjects
    rhino.selectobjects obs
    rhino.copyobjects obs,rp,xyz
End If
next
rhino.enableredraw vbtrue
end sub
main
You need to paste the code into a button like so:
HTH
-Willem
