Pixelated textures in Rendered display on Rhino 9
I’ve been testing Lands Design 6 on Rhino 9 and I quickly noticed that plants look pixelated in Rendered display mode. After some tests, it seems to have to do with the “Use advanced GPU lighting” setting, because when I disable it textures no longer look pixelated. However they still show some transparency artifacts. Nothing of this happens in Rhino 8, with or without enabling that setting.
Pixelated textures on Rhino 9
Here is the 3dm file to test it (no Lands objects, only Rhino primitive objects):
Pixelated Textures on Rhino 9.3dm (1.6 MB)
Hi Albert,
i was able to repeat this using the textures out of your file, thanks for reporting.. RH-98139 It’s the transparency mask that’s failing rather than filtering, with advanced GPU lighting on the masked areas fill in dark instead of cutting out, and since that happens around every leaf and twig it reads as pixelation. Rhino 8 is correct here at its Rendered defaults.
This needs to be resolved urgently, please. We cannot use Rhino 9, at least for Lands users, as long as this issue persists.
I uploaded 2 images of the same Lands project and the same species models, one in Rhino 8 and another in Rhino 9 for your reference.
RH-98139 is fixed in Rhino BETA
