Hi Gurus.
I want to make a pitched roof from the drawing.
The pitch is at the cross section of two green lines above the drawing.
Thank you.
David
Pitched Roof.3dm (11.8 MB)
Hi Gurus.
Thank you.
David
with few images of what you want or what you’ve already tried could be better to help you.
Hi Diego,
Thank you for your reply.
I want to make something like a cone. But the base circle is irregular. Just like the drawing attached.
The position of the center cone is at the cross section of two green lines above the drawing.
I hope it will make it clear.
Thank you.
Hi All,
I have solved the problem. I use Loft and it works.
Thank you.
Pitched Roof.pdf (165.8 KB)
oh you can use ExtrudeCrvToPoint to make that, like making a pyramid from any closed shape.
Thank You Diego.
