I am using pipe command to make a groove on a surface. The first 2 split without issue, but this last one will not split. It says it does not intersect.
In this screen shot I highlighted a curve created by Curve Between 2 sets command. It is clear that Rhino doesn’t think there is an intersection along one side of the pipe.
I try to use “SRFseam”, but I cannot select the seam. I can’t find any seams in my drawing that I can select or modify with SRFseam.
Any ideas?
I guess I can split the pipe down the middle, and mirror the side without a seam to the other seam? I really shouldn’t have to invent weird techniques to make a simple split!
