Hello I’m following a tutorial which is in Windows and the Pipe command offers No Cap. However, in Mac there appears to be no such option. My pipe is coming up with a cap at a jaunty angle which I don’t want. How do I get it to produce a pipe with no cap please? TIA Diane
Hello - please post a file with just the curve you are trying to pipe.
I’m so sorry I have no idea how to do that.
- Select the curve you want to use with Pipe.
- Export it to it’s own 3dm file.
- Use this tool to add it to a reply:
Got it thank you
Piped ring prong.3dm (1.5 MB)
Hello - the end of your curve has a control point askew near the end and that is causing your pipe to fold on itself - delete that point and you should be OK.
It worked. Thank you. More things learned!
