[Pipe] Curve to Pipe is not working on some Curves
Hallo
Some of my curves are not able to extrude to a pipe.
In the following Screenshot u can see that the Grasshopper sript was not able the extrude the Curves. If i select each Curve single, they are also not extruded. U can see which Curve worked in Screenshot A.
I would like to understand the reason ?
Thanks for help
Version 8 SR10
(8.10.24212.13001, 2024-07-30)
Screenshot:A
Also …
Screenshot:B
If i turn of the Grasshopper Preview for the small pipe i cant even see the Preview from the big pipe anymore.
Screenshot:C
If i turn on both Brebs i can see the big Brebs.
Grasshopper file:
Curve_to_pipe_01.gh (5.8 KB)
Rhino file:
Curve_to_Pipe_01.3dm (379.0 KB)
Hmmm, weird how moving it closer to origin makes it a valid brep.
I dont undetstand where the problem is, must be somethink with the Curve ?
Brep are “invalid” when using “round”.
At “flat” they are “closed Breps
But why ?
I’m not sure why proximity to origin is affecting brep validity. Someone from Mcneel would need to chime in.
I don’t know why but also rotating the curves by a random angle, piping them, then rotating the pipes back produces a good result:
also, moving the curves even very very very far away from the origin produces a good result:
it looks like the Pipe Component does not like the initial position of your curves .____.
how did you get those curves in first place?
I wouldn’t try these dimensions “line length are 108000 mm!” in millimetre Unit in Rhino.
change your rhino file with scaling the object On option and tweak your GH def
