Pictureframe blank
When jpeg file is selected and a frame dragged out, only a blank surface appears, with no image. Why ?
There’s some issue with the NVIDIA graphic card. It dissapears from time to time, but whenever I reboot, it comes back on again. Could this be the reason ?
Thanks.
Select the blank jpg and try Reparametarize in the command line. Does that help?
Which version of Rhino are you using?
If Rhino 6, please post the result of the Rhino SystemInfo command here.
Thanks, cosmas, it seems to be working, at least for now.
I’m using Rhino 5. The problem is solved at least for now thanks to cosmas.
