Photogrammetry Mesh to Rhino Surface Topography
I am trying to create a rhino surface (site topography) from a photogrammetry mesh (from drone reality capture / use of the Heron plugin). Conceptually, I am sticking a bunch of vertical lines into the photogrammetry and using all of those intersections (points) to create a nurbs curve and eventually loft them into a rhino surface. I realize the Heron plugin can provide a topographic surface but it is not super accurate in my experience, especially if you crank up the resolution on the Heron Photogrammetry brought in. Please let me know if I am approaching this solution from the wrong angle. Otherwise, I am sturggling with two major things in my process:
  1. The sample photogrammetry in the file below is broken up into open meshes. I am trying to use the path mapper to group my points in a straight line for nurbs curve generation. (See top image in PDF below)
  2. How to “smooth” out the surface from buildings, tress, cars, etc. Would I take average sampling of surrounding point z values? Or should I try to overwrite the z values that are extremities?
Any thoughts on this would be greatly appreciated!
MeshtoSurface.pdf (1.5 MB)
MeshtoSurface.gh (37.8 KB)
MeshtoSurface.3dm (1.9 MB)
The biggest issue is the low resolution of the mesh.
Anything you do with nurbs will decrease the accuracy due to interpolation, unless you simply convert each triangle to a nurbs surface. Creating a nurbs surface from each triangle is typically not the approach to create a nurbs surface but in this case it may be the best option. You can sample more points on the mesh, but generating curves and a surface based on sample points will still result in interpolation.
If you can get a higher resolution mesh from the photogrammetry you could end up with a result with better accuracy, although it would still be interpolated.
No difference in accuracy between using the mesh faces directly for interpolation or using the mesh faces converted to individual NURBS surfaces for interpolation.
Right, the difference in accuracy (interpolation) is when curves are used to generate the surface. Since the mesh is very low resolution, interpolation may be significant.
