Hi
I’m trying to match geometry i have with an image. I know it should be possible with perspectiveMatch. But I somehow have issues getting it to work. Either it just stops the command or it doesn’t work properly
Does somebody have experience with this command? and knows any tipps or tricks for this to work well?
Hi Chris, it seems to get at least a plausible result here - I marked off 6 points on the model that I guess I can see in the image - you need to place at least 6 pairs. It might be possible to locate a few more points and maybe adjust the lens a bit as well.
