PDF import circle become curve
I have a PDF export from AutoCAD, there are a few circles, but when import the PDF to Rhino, the circle became curve.
How to import PDF with circle correctly?
I think you have to check the export options in AutoCAD first.
There is no such thing as a circle (or arc) in PDF. If you want a circle you would need to use DXF or DWG format.
