Pattern in VisualARQ Plan View
Hello, there is an issue regarding Plan Views I don´t understand: I created a new Section View Style with a solid pattern, in order to overwrite the pattern defined in the Wall Wtyle, and this just works fine! So why isn´t it possible to do the same thing with Plan View Styles? I created a Plan View Style with a solid pattern, however the solid pattern does not overwrite the wall pattern. What causes this difference to Section Styles?
viewpattern
Hi @david.adam,
Plan views should work as Section views, but we haven’t implemented yet this “overwrite section attributes by style” feature in Plan view styles. We will do it in future versions. I’ll keep you posted.
@david.adam good news: we have just released a new version of VisualARQ (2.12) which adds the option to override attributes to Section and Plan Views by style (in a more consistent way than before). Check this out here: Section View Attributes Overrides - VisualARQ - YouTube
And the news of the new version: VisualARQ 2 - Version 2.12 released
