Hi everyone! i’m tryig to code the pattern i’ve marked in yellow into grasshopper. and i also want to draw this pattern onto a diamond grid. there are no diamond grid selections in the grid tab and i also don’t know how to replicate the pattern. i’d really like some help! (also i’m fairly new to grasshopper so pls be kind
thanks! i tried to open this but boundary surfaces command turned orange? what do you think the problem is?
I can tell from your image that Offset Curve failed to produce any output. The code works for me but click the small orange box at the top-right of Boundary to see the error:
- Input parameter E failed to collect data
Odd that I don’t see that small box on your screen shot? “R6 Educational Lab License”?
Wait, that doesn’t even look like @HS_Kim’s code? I guess you re-arranged it to avoid overlapped components using ‘Display | Draw Full Names’?
yes, i did rearrange it but it was still orange the first time i opened the code. the error box says “planar surface routine returned no results” what does this mean?
