_Patch. 1 closed curve. Python
I need to make a patch from one closed curve.
rs.Command(‘_SelCrv’)
rs.Command(‘_Patch _Enter’)
#rs.AddPatch
Help me please
Hi @Alex_GM,
Use Brep.CreatePatch.
– Dale
Thanks. Can you write more? I need to do this in order to work through python.
Hi @Alex_GM,
How about this?
import Rhino
import scriptcontext as sc
def test_patch():
    filter = Rhino.DocObjects.ObjectType.Curve
    rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select curve", False, filter)
    if not objref or rc != Rhino.Commands.Result.Success: return
    crv = objref.Curve()
    if not crv: return
    brep = Rhino.Geometry.Brep.CreatePatch([crv], 60, 60, sc.doc.ModelAbsoluteTolerance)
    if brep:
        sc.doc.Objects.AddBrep(brep)
        sc.doc.Views.Redraw()
if __name__ == "__main__":
    test_patch()
– Dale
Thank you very much.This is magic. You helped me a lot.
