Thomas_P
(Thomas P)
September 4, 2023, 6:57am
1
Hi there!
I have a curve and a point of that curve at parameter t. I want two other points that have the same distance from that point in either direction of the curve.
However, I learned that parameter t is not equally distributed along the curve (Rhino - 3 Parametric Curves and Surfaces ). That means, that the point at t-i of the curve has not the same distance as t+i to the point at t.
So, how I find two points that have the same distance in either direction to point at t on a curve?
I’m programming in C#, but answers using Grasshopper components are also helpful. Thanks for any help!
Assuming that “same distance” means what the confirmation part does (or you mean the pt.DistanceTo(otherPt) thing?)
if(crv == null || !crv.IsValid) return;
if(d < tol) d = tol;
double CL = Math.Round(crv.GetLength(), 3);
Print("Length: {0}", CL);
double DL = Math.Round(crv.Domain.Length, 3);
Print("DomLength: {0}", DL);
Print("P0 Length: {0}", Math.Round(CL * t, 3));
Point3d p0 = crv.PointAtLength(CL * t);
pointAtT = p0;
Point3d p1 = crv.PointAtLength(CL * t - d);
point1AtD = p1;
Point3d p2 = crv.PointAtLength(CL * t + d);
point2AtD = p2;
// ----------------------------------------------------confirmation
double t0; crv.ClosestPoint(p0, out t0);
double t1; crv.ClosestPoint(p1, out t1);
double t2; crv.ClosestPoint(p2, out t2);
try{Print("L1: {0}", Math.Round(crv.Trim(t1, t0).GetLength(), 3));}
catch{ Print("invalid t1");}
try{Print("L2: {0}", Math.Round(crv.Trim(t0, t2).GetLength(), 3));}
catch{ Print("invalid t2");}
As a small challenge: check d in relation to crv Length and t … and act accordingly (d should be >= tol).
Thomas_P
(Thomas P)
September 4, 2023, 9:15am
3
Thank you for your response!
.PointAtLength
seems to be the way to go. However, there is still one problem… I calculate t
by:
crv.ClosestPoint(myPointOnCurve, out double t);
where the parameter t
is not normalized (unfortunately). That means
won’t return the correct point on curve. Do you understand the issue? What would you suggest?
Thanks again for your help!
Edit: I tried to normalize t
by
Point3d pS = crv.PointAtStart;
crv.ClosestPoint(pS, out double tS);
Point3d pE = crv.PointAtEnd;
crv.ClosestPoint(pE, out double tE);
double normalizedT = (t - tS) / (tE - tS);
and by
double normalizedT = (t - crv.Domain.Min) / crv.Domain.Length;
which both did not yield the correct result. I think the reason is that t
is not equivalently distributed.
Thomas_P
(Thomas P)
September 4, 2023, 9:41am
4
I found a solution:
Curve trimmedCrv = crv.Trim(tS, t);
double lengthToMidPt = trimmedCrv.GetLength();
Point3d p1 = crv.PointAtLength(lengthToMidPt - d);
Thomas P:
not equivalently
Since p1/t1, p0/t0 and p2/t2 yield Intervals used to Trim (in the confirmation part) the crv into segments that have the same (rounded ) Length … well … it’s rather obvious my dear Watson.
Curve_PointsAtDistInRelationToPt_V1.gh (12.9 KB)
PS: As a challenge mastermind the approach for a closed Crv.
