I have a set of arbitrary curves (pink) with varying length.
I want to evaluate each curve at a parameter so that the distance between each evaluation point is the same, or a multiple of that distance.
The example is manually made. Now, is this possible to identify this common distance in Grasshopper??
I can’t come up with a solution
EDIT: I realise now that my problem is very complex and that there might be an infinite amount of possible solutions
