Basically, I have a product that has been fully developed in Grasshopper and automated for different dimensions, which generates a 3D mass as part of the process. I then need to create a Revit family for it with the same parametric capabilities.
My question is: is there a way to use the existing Grasshopper script to generate a parametric Revit family?
Hi @santacero yes you can create the revit families from the grasshopper script but in this case they will be controlled by the grasshopper.
If you want to have those parameters in revit then you have to manually create the families. In this case grasshopper can also control these parameters through different RIR components.
