There is any way, studies or cases of someone who tried, or did, parametric families in Revit using grasshopper fully editable in Revit? It can be using programming or anything like that too, just searching for sources of knowledge. Thank you.
There is good documentation on the regular updates. No components for family constraints yet.
https://www.rhino3d.com/inside/revit/beta/guides/revit-drafting
This looks promising for parametric BIM Family building.
https://www.bimobject.com/en/bimscript/product/bimscript3rhino
Thank you for your attention, this looks promising, I will try. The second Link, there is any perspective of seen this on Rhino 6?
Its an active project developed in C#, so most likely still functioning in R6. Lots of potential if you are looking to create catalogs of parametric families across multiple platforms.
