It’s great that rigid modules are do-able but just wanted to clarify that the primary functionality I’m seeking from PanelingTools is to find a way of extending the panel grid across multiple stitched surfaces that make up any given Polysurface. The proportions of the modules vs Polysurface I provided was perhaps impatience on my part. I’ve provided a better example of what I’m hoping PanelingTools can do – rigid-panel not only the middle surface but cross the “border” and cover the rounded surface… (I only manually laid down a partial patch as an example.)
Same for the starfish… at the very least panel ALL of the upper surface. I’ve exploded them into color-separated sub-surfaces in the following picture, but the pressing question is whether PanelingTools can truly panel the stitched collection without breaking up the paneling pattern. Shrink the rigid module to 1/4th the current size for a more form-fitting flow.
