Hey everyone!
I’m making a ‘creative’ task in RhinoPython
So I tried making this ‘wall’ kind of thing with empty squares of different sizes in it by extruding a panel. The code totally worked fine. Now i wanted to add a sinewave, where all the squares should stay above (but still inside of the panel!). Only problem is that rhino doesn’t want to draw any squares anymore right now. I think the problem is somewhere at the list of zCoors. Although i am quite sure that the given coordinates are right coordinates to draw squares onto.
Thanks for your help!
Marnix
import random as rd
import math
rs.Command('SelAll')
rs.Command('Delete')
# global variables
panelWidth = 300
panelHeight = 100
iterationNum = 200
radiusMin = 1.5
radiusMax = 8
extrudeHeight=5
minGap = panelHeight/30
gulfSize=10
wavePoints=[]
zCoors=[]
for x in range(0,panelWidth):
z=3*math.sin(x/5)
liftedzCoor=z+panelHeight*2/3
zCoors.append(liftedzCoor) #The zCoors of the squares should be above the wave
point = (x,0,z)
gulfPoint = rs.CreatePoint(point)
wavePoints.append(gulfPoint)
sineWave=rs.AddInterpCurve(wavePoints)
rs.MoveObject(sineWave,(0,0,panelHeight*2/3))
# Step 1: Create a permutation
def MakePolygon(inputSize):
xCoor = rd.uniform(0,panelWidth) # draw a square with a certain size at a random center inside the panel
zCoor = rd.uniform(zCoors[int(xCoor)],panelHeight) #making sure the zCoors are actually between the wave and the panelHeight
randomCenter = rs.CreatePoint(xCoor,0,zCoor)
print(randomCenter)
primitiveSquare=rs.AddRectangle(rs.WorldZXPlane(),inputSize,inputSize)
rotatedSquare=rs.RotateObject(primitiveSquare,randomCenter,45,axis=(0,1,0))
newSquare=rs.MoveObject(rotatedSquare,randomCenter)
return newSquare
# Step 2. Check whether this permutation is valid
def TestPolygon(inputPolygon):
if rs.PlanarClosedCurveContainment(inputPolygon,panel,plane=rs.WorldZXPlane()) == 2: # test if inputPolygon is inside the panel
testResult=True
for square in allSquares:
if rs.PlanarClosedCurveContainment(inputPolygon,square,plane=rs.WorldZXPlane()) != 0 : #test if inputPolygon and square intersect
testResult=False
break
else: testResult=False
return testResult # return either True or False
def TestPolygon(inputPolygon,inputSize):
testResult = True
if rs.PlanarClosedCurveContainment(inputPolygon,panel,plane=rs.WorldZXPlane()) != 2: # test if inputPolygon is inside the panel
testResult=False
else:
testResult=False
break
else: #test to make sure there's enough space between squares to be able to construct it
centerPoint1 = rs.CurveAreaCentroid(inputPolygon)[0] #center of inputPolygon
distance1 = rs.Distance(rs.PointClosestObject(centerPoint1,inputPolygon)[1],centerPoint1)
centerPoint2 = rs.CurveAreaCentroid(square)[0] #center of square
distance2 = rs.Distance(rs.PointClosestObject(centerPoint2,square)[1],centerPoint2)
if rs.Distance(centerPoint1,centerPoint2) < distance1 + distance2 +minGap:
testResult = False
break
panelPlane = rs.WorldZXPlane()
panel = rs.AddRectangle(panelPlane,panelHeight,panelWidth)
# Step 3. The Forcing loop
allSquares = [] # list of all squares
for counter in range(iterationNum): # this program will run iterationNum iterations
sizeSquare = (radiusMax-radiusMin)*counter/iterationNum+radiusMin # gradually change the square size, remap from counter
newSquare = MakePolygon(sizeSquare) # draw a square permutation
if TestPolygon(newSquare)==True: # test whether the square permutation is valid or not
allSquares.append(newSquare)# append the newSquare to the allSquares list if valid
else: rs.DeleteObject(newSquare)
# delete the newSquare
# make the surface and extrude
squarePlane = rs.AddPlanarSrf(allSquares+[panel])[0]
line = rs.AddLine((0,0,0),(0,-extrudeHeight,0))
rs.ExtrudeSurface(squarePlane,line)
