Please see C# command, created as part of the Programming Architecture C# plugin course I’m following.
The command is meant to prompt the user to select 4 points, then 20 panels are distributed at random angles, marked with text dots, and a parent (and 2 sublayers) are meant to be generated. I’ve done my best to go through the videos again, but I cant’ find the problem. I had the command working fine, but now it’s only generating the parent layer “L” and is exiting the command.
Any help would be appreciated.
Thanks,
Dan
