Pancake: Put emergency files in subfolder!?
@gankeyu
I like the Pancake emergency feature and it has saved my butt a few times already. What I don’t like is how it “spams” the folder with tons of files (in .gh AND .txt format).
It really clutters the folder with files.
Idea: Can we get an option to put the files in a subfolder called “Pancake Emergency” or something. That way the folder stays a bit more clean, but the files are still accessible in the appropriate folder. Saving ALL emergency files to one folder makes it much harder if you work on a file server.
So if we could get another option to store the files in a subfolder that would be great. Also an option to turn off saving as .txt would be great.
Thanks for considering.
Sure. I will PM you a beta version later.
Hi @gankeyu ,
I would also like to express a gratitude for developing and releasing such an amazing plugin as Pancake. Thank you for that.
And I have the same question: is there an option, that I can uncheck in order to prevent the creation of “PancakeEmergency,gh” and “PancakeEmergency.txt” files?
If you don’t want this feature, you can uncheck Hang Protection in the Pancake menu.
Thank you very much @gankeyu .
So what does Pancake consider as “hanging too long”? It means the current solution has been executing for more than a minute, 5 minutes?
61s ~ 65s, to be exact (the time only counts when GH doesn’t respond to user interactions; sometimes a solution can be long but still responsive)
Thank you again @gankeyu .
All praises for your work up until now. Pancake is truly a brilliant plugin!
