PackageManager bug - Installed Package Properties empty
Hi @will,
using Rhino for Mac (8.16.25028.13002, 2025-01-28), the Installed tab of the _PackageManager dialog does not show Author, Date published, Url or Description. The package Name is shown properly. I’m not sure if it should show the project icon used when building the package ?
thanks,
c.
If you’re building from Visual Studio, the info is inherited from Assembly.info file.
Hi @xliotx, i’m actually builing from _ScriptEditor which stores the info in the manifest.yml file. On Windows the information is displayed properly.
@will, the package is not on McNeels’s package server but on my own which is hosted locally.
thanks,
c.
Hi @will,
the problem described in the opening post is still there using Rhino 8 SR20 (8.20.25147.11001, 2025-05-27). After installing my yak package using drag and drop, i see it in the PackageManager Installed tab. The fields for Author, Version, Date published, Url and Description are all empty. Only the fields for Name and Installed display information.
can this be fixed please ?
thanks,
c.
@clement I can not replicate this issue. I see author name listed there. Would you mind sharing the .yak file of your package so I can look into it? You can DM me the file.
Hi @eirannejad, i’ve sent you the yak in a DM. Thanks for looking into it.
_
c.
Hi @will and @eirannejad ,
the problem described in the opening post is still there, now using Rhino 8 SR22 and SR23 (Windows). I’ve tried it on 3 different systems. The PlugIn was compiled with ScriptEditor and installed via drag & drop.
_
c.
