Package Manager Installed Tab nothing appears
Hello thogether,
when I open the Package manager in the Online Tab is everthing fine.
Installed Tab it searches for a while but nothing appears.
Any idea what is going on?
Hi Martin -
Did you install anything (and restarted Rhino)?
Please run the Rhino SystemInfo command and copy-paste its output here.
Hi Wim,
just installed the latest update.
You may also have a look at this post. It might be related? Import Alembic File
Rhino 8 SR22 2025-8-5 (Rhino 8, 8.22.25217.12451, Git hash:master @ 96429e6361004c775cd83973f2148f3943b5e512)
License type: Commercial, Build 2025-08-05
License details: Stand-Alone
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63GB)
.NET 8.0.14
Primary display: Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 2-28-2025 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA RTX A3000 Laptop GPU (NVidia) Memory: 6GB, Driver date: 6-8-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 573.40
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2025
Driver Version: 32.0.15.7340
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\pollination\plugin\8.0\Pollination\Environmental_Analysis.rhp “Environmental Analysis” 0.0.0.0
C:\Program Files\pollination\plugin\8.0\Pollination\Pollination.RH.rhp “Pollination.RH” 1.64.5.0
C:\Program Files\pollination\plugin\8.0\Pollination\Pollination.RH.Core.rhp “Pollination.RH.Core” 1.64.5.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.297\net8.0-windows\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.297.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.64.5\net8.0-windows\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.64.5.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationsWerkzeuge”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.22.25217.12451
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.22.25217.12451
Hi Martin -
I assume you mean that you installed the latest version of Rhino. I was asking if you had installed any packages using the Package Manager.
The “Import Alembic File” plug-in is not available on the Package Manager. Installing it by drag-n-dropping the .rhp file onto Rhino or selecting it from the Plugins page in the Rhino Options does not make this uninstallable from the Package Manager. Those are two different and separate installation workflows. From the Plugins page, you can locate the folder in which the plug-in installed and delete that file in that folder.
Hi Wim,
I deleted the .rhp file. Restarted Rhino. The plugin isn’t shown anymore.
The behavior of the the Installed tab in the PackageManager is still the same.
Hi Martin -
You’ll need to provide more information about that. I’ve asked you if you have installed something through the PackageManager twice without getting an answer.
Sorry @Wim, for not clearly responding. No, I didn’t use the Package Manager at all before.
Hi Martin -
Thanks. Then the behavior of not anything being shown there is correct, if you ask me.
