Package manager failing to fetch
I have used package manager multiple times before, but now it tells me “Failed to fetch packages from source https://yak.rhino3d.com The GET timed out. Are you sure there is a package folder/server here?”
I’m trying to download “meshedit” and “weaverbird” to use with kangaroo. The following is my systeminformation.
Rhino 8 SR29 2026-3-4 (Rhino 8, 8.29.26063.11001, Git hash:master @ bbd126f84fcdaf7a974615b7c9f4f8667571c147)
License type: Educational, build 2026-03-04
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.14
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-22-2023 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 3-21-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.95
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-21-2024
Driver Version: 31.0.15.5195
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.29.26063.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.29.26063.11001
Hi, @Melina_Ellvin.
Has this issue been resolved? Generally, this is often an Internet access issue related to Rhino. Is you computer managed by an IT department? Do you have an active firewall setup blocking Rhino from reaching the Internet? You may also want to check your “hosts” file and delete anything Rhino/McNeel related.
Here’s a similar topic:
We recommend searching our forum for keywords related to your question, before posting, if you didn’t do so already.
Rhino 8 – PackageManager: “Failed to fetch packages from source(s): https://yak.rhino3d.com – The SSL connection could not be established”
Cause: connections to Rhino’s package server (hosted on Amazon CloudFront) get dropped when they go over IPv6. Over IPv4 they work fine. The fault is in the internet provider’s IPv6 route, not in Rhino. On fresh Windows installs, the Amazon root certificate may also be missing.
Fix (run in PowerShell as Administrator, then restart Rhino):
  1. Make Windows prefer IPv4 over IPv6 (IPv6 stays enabled):
    netsh interface ipv6 set prefixpolicy ::ffff:0:0/96 60 4
  2. If it still fails, install the Amazon root certificate:
    Invoke-WebRequest https://www.amazontrust.com/repository/AmazonRootCA1.cer -OutFile "$env:TEMP\AmazonRootCA1.cer"
    certutil -addstore Root "$env:TEMP\AmazonRootCA1.cer"
To undo step 1: netsh interface ipv6 set prefixpolicy ::ffff:0:0/96 35 4
