Hello, I just upgraded from Rhino7 to Rhino8 and now my Osnaps aren’t working anymore. I checked the “only selected objects” and it is unchecked.
Hi Jason - please try this - start a new file and make a reactangle in Top. Now start the Line command with End and Mid osnaps enabled and start or end the line on an end or mid point - does that fail?
Check your Selection Filter too.
It’s possible some object types are turned off.
Thank you, that did it. For some reason, everything was unchecked in that submenu.
