Orient on surface with curve
is there a command orient on surface command that you have the option to select a curve to follow? ive tried orient on surface, splop, curve along surface. any commands im missing? basically a orient on surface with a choice to select a curve to follow in the command line.
Hello - if you need to do this a lot, you might have a look at Armadillo in Food4Rhino
