I’ve recently discovered the AddBolt command using the Package Manager and really LOVING the ability to orient the bolt onto any surface, as a step within the command. It is so much more direct than dealing with cplane options that may or may not be set correctly for that particular command at that particular moment.
Is there any chance we could add an Orient onto Surface option onto EVERY command that is generating something, ie: curves, surfaces, solids, meshes? Based on my AddBolt experience, I feel like it would be a super-intuitive enhancement!
Maybe not the same…more basic but related? I really like the AutoAlignCPlane (set to object); this is also specially handy when you’re doing subselections via Ctrl+Shift:
Yes I have been using that method as well, it’s great!
I guess the only difference with it being in the command is the ability to pick the surface AFTER initiating the command, which feels a bit more intuitive to me. I also found I was switching my AutoCplane settings too often for different tasks…
But I’ll persevere with it, I’m sure there’s a sweet spot there somewhere!
