I have three branches of rectangles, and I want to join their top and bottom line segments, respectively, into two parallel curves, and pair them if they belong to the same cluster of rectangles.
The workflow attached below does the above by adding the rectangles one by one (using the item selector (from the Ladybug Tools) highlighted in red in the first image below). (The custom preview lineweights component is from the HUMAN package).
It works for the first 47 rectangles (see the 2nd image below). However, it breaks when coming to the 48th, 49th, 54th, 58th…and many other rectangles, and the paring of the joined curves are not correct (see the 3nd image below). The error doesn’t seem to have any pattern so far.
I’m not sure what is causing this issue, and help is greatly appreciate.
problem with order of joined curves and their paring.gh (32.1 KB)
