Join Curve
Hi!
Please help to combine the curves in the correct sequence.
Thank you
Join Curve.gh (6.7 KB)
Join Curve.3dm (111.1 KB)
Do you need to maintain the index numbering as shown currently?
Thanks for the answer! No, it is not necessary to support indexing. The main thing is that the curves are logically connected
Join Curve_re.gh (32.2 KB)
if you don’t want to select the curves in order, it sends us to another problem, pairs of closest points. Kim’s solution will work until some threshold, when there is too many curves.
another idea to consider
Thank you
Often the list of curves will be chaotic
