Order intersection points according to intersection planes or surfaces
Hi all and happy holidays,
I have a question regarding data structure for matching interpolation points to their corresponding ‘parent intersection surface’. See attached file.
I have a set of curves intersected by a set of surfaces:
In order to make curves from intersection points right where surfaces are intersecting I have to use ‘cross reference’ (ONLY ‘upper triangle’ option) then ‘shift paths’ then ‘match tree’:
Is there a more elegant way of doing this? Tried the path mapper but it limits editability once I change original amounts of intersecting planes or curves.
Thanks in advance for your help.
intersectionproblem_01.gh (105.6 KB)
intersectionproblem_01_re.gh (109.6 KB)
IMO, you don’t have to use Cross Reference andMatch tree.
Hi @René_Corella,
It’s simply a matter of organising the trees in a simpler manner, by grafting and simplifying the right outputs.
In my opinion, there’s no need for cross-referencing and matching data trees in your example.
Happy holidays to you too. :santa:
intersectionproblem_02.gh (102.6 KB)
(I guess you were faster, @HS_Kim . Happy holidays to you, too.)
many thanks HS_Kim
hhmm, thanks to you as well @diff-arch + @HS_Kim - the original model has the curves unflattened but I cannot recall if I ever hit simplify on the output intersections, though - most likely not - ironically (evidently) not needed as shown by @HS_Kim- did try pshift from intersections and totally forgot about flip matrix right after yet did use it only at the end - what a clown :clown_face: thanks for your time and the slap in the face!
Giving it a try tomorrow evening. Once again thanks + Enjoy the holiday!
