Hi I tried creating a neighberhood inside an area of a curve with vorony streets and internal backyards.
it works, However the boundry surface has a runtime warning. rhino and grasshopper files attached
help.3dm (519.7 KB)
help.gh (18.0 KB)
Check this:
- No need for the path, you can simply feed the curve into a srf component.
- This appears to be a planar voronoi. No need to use the 3D voronoi component.
- You can split the surface with the cell outlines.
- You can plug multiple values into the distance input. Use shift paths to have two curves per branch for the final surface creation…
help.gh (18.7 KB)
PS: it’s called Voronoi and I internalised your input curve.
Thank you very much!
