When I use the command extrude crv and I did the extrusion, it see like a superficie curves
HELPPPP
Welcome to posting on the Rhino forum.
The polyline is the input to the extrustion. You used ExtrudeCrv with the option DeleteInput=No. If you want the input to be deleted use the option DeleteInput=Yes
Or are you asking about something else?
in the commandline,
click where it says output=SubD
it should change to output=surface
i guess for you output is resultados…
I want to do a solid shape, not only the superfaces , then I used the command subD, but it generate curves shapes without solid
To get a solid, your curve needs to be closed. To get straight faces, you need to change the output to Surface instead of subd
ohhhh thank you, you was right, I didn’t see the option solid so i think that the only option was subD
