Hi!
Whenever I run an analysis in Karamba a warning pops up saying “OMP: Warning #97: Requested number of active parallel levels “-2147483648” is negative; ignored.”
I am using the newest Rhino 8 (8.15.25013.13001, 2025-01-13)
And the newest Karamba (3.1.50121.0)
but the warning also came up before I updated rhino and karamba to the newest version.
Is there anything I can do to avoid getting this warning? I have tried searching for it and it suggests it has something to do with the configuration of OpenMP?
Let me know if you need any more info - thank you!
Thank you for your reply!
I do get results from Karamba3D (i.e. it does not crash) so there is not a problem in that case other than I get many warnings if I do several analyses.
It is definitely possible that I have other plugins which use an old version of libiomp5md.dll - I’ll try double check that.
I’ll keep an eye open for the next service release - thanks!
