Old Fillet Surface Command in v9
In v9, is there a way to use the old fillet surface command? I had icons for creating a fillet that could automatically trim, or trim and extend, or just extend. Even though I see a place for the new dialog box, I just feel pressing one button easier than going thru the dialog box.
Have you tried using the command using a dash prefix
Like this:
-FilletSrf
Prefer to use the underscore-dash version, because that works in all languages. The dash-only only works in English.
_-FilletSrf
Also: you’re not getting the “old” FilletSrf command. You are using the scripted mode of the command that does not show a dialog. The dash in front of any command will run it in scripted mode.
