How do you turn the properties box on and off?
seems to have went missing.
You mean the properties panel?
Right click on other tabs and select it.
Or cal the command “Properties”.
When I type in offsetmesh the properties box does not pop up, I can only use the command line to adjust.
I.E Offset Solid, not the popup box where I can check Solid, or both sides etc.
Hi Ugy - in V7, OffsetMesh
does not have a dialog box, options are all on the command line.
Thanks, new to 7
