Does the Offset Curve component have a maximum number of control points it can handle? My curve has 6812 control points and the offset fails after a certain percentage. I can flip the curve and the problem occurs on the other end of the curve.
Attach your file please!
This won’t be possible. It’s much rather a question to the developers whether the command has an actual maximum number of points it is capable of processing.
I attached a simplified example. Why does the offset fail on this curve?
Please note, I’m working with an interpolated curve, not a polyline.
21_11_25_offset_fail.gh (23.9 KB)
Well Jordi, you changed the input values. And it seems you might have different tolerance settings. Or for some reason your offset curve has 20’000 something control points while mine has 37117 control points.
Below is my system info:
System info Martin Siegrist workstation
Rhino 7 SR13 2021-11-16 (Rhino 7, 7.13.21320.13001, Git hash:master @ e803eedb640e6d2f37b95fd3d0eac5af5532def7)
License type: Kommerziell, build 2021-11-16
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 10-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.39
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-13-2021
Driver Version: 30.0.14.7239
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.4.0.0\KeyShot9RhinoPlugin\Rhino 7\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.13.21320.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.13.21320.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.13.21320.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.13.21320.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.13.21320.13001
Rhino 7 SR12 2021-11-9 (Rhino 7, 7.12.21313.06341)
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 30Gb)
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 11-6-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.30
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 11-6-2020
Driver Version: 27.21.14.5730
Total Video Memory: 11 GB
Model Units: Milimeters
Absolute Tolerance: 0.01 units
Angle Tolerance:1.0 degrees
Length: 3.7524e+6
Nº of Points: 43437
I don’t think this has to do with hardware specs.
While working on a much bigger curve with nearly 90’000 points, I realized that cursor tool tips decrease performance drastically. Is that a known problem / limitation.
So far my workaround for the offset fauilure is to split the curve into multiple segments but that leads to other problems again …
Today I had enough and I downloaded Clipper.
While it takes 23 seconds to show the control points, the GH Clipper component Polyline Offset rebuilds and offsets my polyline in just 1.2 seconds and the result is a closed curve.
I’m trying to work with native components whenever possible. How does Clipper do this so quickly and perfectly right? Is there any plan to integrate what clipper does into native Rhino commands and Grasshopper components?
Clipper is able to solve things by only (1) supporting polylines (not arcs, circles, etc.) (2) only supporting planar curves (3) placing all lines on a ‘bitmap’ all points are internally rounded to integer numbers, greatly simplifying the process of solving overlapping/nearly overlapping curves.
