Hi, i need to offset the curve as shown below. How do automate a script to perform such offset?
Offset.gh (23.9 KB)
plug those curves into the offset component.
Is your issue the direction of offset? Two of the curves need a negative distance to match your posted image:
Why are you using a cluster for Offset instead of the standard component? This version below replaces your cluster with standard Offset. requiring the negative distances to be reversed:
Yes, the direction of offset. Please ignore the offset cluster. Instead of manually handling the offset direction by inputting negative value. How can i offset in the manner with the same result as yours>?
for a situation like this one it seems you were approaching it right with a surface in between the start points of the curves.
this could be a way to ‘automate’ it in a scenario like yours
Offset.gh (20.0 KB)
Sick mate! Whats the main function to use CCX if u can use end points for the V-Isocurve?
you’re right!
haha gh is so redundant that it affects you
Either way, cheers for putting the puzzles together.
