The closed breps at left of following image were obtained from 3D veronoi. The “box” used to define the 3D veronoi consists of non-planar surfaces. As a result, some faces of these breps are non-planar surfaces.
I tried to offset the boundaries of all faces and carve out a hole, if the face is big enough. However, it does’t work on some of the faces as shown in following images.
Thank you so much man. It works prefect! Much appreciated!
By the way, is it possible you can point me to any tutorial of how to implement Rhino command in grasshopper? Thank you.
