I wonder.
Is there any script that supports to “offset” the middle edge of the letters
There’s a script by @laurent_delrieu with a few options…
You’ll find the latest version of the script in this thread here:
Hello. Grasshopper I have never used.
Is there any script “Automated Centerline Extraction”
I just need to create 1 centerline between the objects.
The rest I will do it manually
There’s Tween but the input for that command is two lines / curves
Hi. “Tween” does not work with the text object
