Hello @DavidRutten
Can you add two components to create line from center like in rectangle, cube
And offset point, like offset line.
And boolean input for offset component to enable offset in two directions
Hello @DavidRutten
You can probably DIY on this, although I don’t know how they handle merge requests.
rhinoscriptsyntax library. A bit of a hack.Thanks, i will check it
