I do not know what happens in Rhino 6… you could add the ability to select more than one curve, not only a curve at a time? Example: if you have many edges, it’s frustrating having to perform an offset on the surface one at a time; it would be more practical for you to select the ones that interest simultaneously.
It would be possible?
the maximum would be if the command could also work for polysurfaces.
