I often have a problem with offset of curves. I made a small sample where the problem is shown. The crv offset is unpredictable. Why are some values indented correctly and some not? Can someone please tell me where I am making a mistake? Please help, thanks a lot
I’m sorry (it’s not my cluster), I tried more ways to offset and forgot to return the standard gh component to the sample. I have the same problem with the native gh offset_crv_issue_v_02.gh (8.8 KB) component.
Nom, you can consider use “Offset curve loose” which just move the control points of your curve, but is a good solution if you work with polylines.
… but, due to another old bug, you’ll need to explode and join the polygon before that.
