Offset Crv command
Is there a way to make the offset crv command not just for a single shot? I have a whole bunch of curves that I need to offset with the same distance and have keep re-staring the command after each one.
Hi Denis - in V6/WIP, OffsetMultiple, but there is probably a script or three out there for this in V5- I don’t think I have one. One trick is to use the repeater character:
*Offset
that will just keep running the command until you stop it.
–Pascal
Thanks I will give them both a try.
