HELLO EVERYBODY,
IM TRYING TO OFFSET A CURV3E MULTIPLE TIMES ,
i ve tried doing it with a series component but it didnt work
does anyone knows how?
OFFSET REPEAT.3dm (40.9 KB)
OFFSET REPEAT.gh (8.0 KB)
HELLO EVERYBODY,
thanks for your answer
yes,
only that i would like to conrtol the offset distance,
and also to have them offseted from the original curve - right now they are far away.
I’m not very clear on what you are trying to do. Maybe you could make a sketch, or make an example in Rhino, to better explain.
I just realised that your rotation output is plugged into the series start value. This is giving the first offset a larger number than the others.
If you dont need the rotation, it could be something like this.
You were right,
Its the rotation.
Thank you very much.
