I’m trying to create an offset surface for further processing. I create a series of contours, offset these, however something in the data management excludes a curve(s). The problem curves/surface can vary based on the offset parameter.
I could loft between the internal curves, then remove with Boolean but feel there is an easier solution. Seams simple but I can’t fix it via the data tree. The curves are planar too.
Thanks!
Contour & Surface Boundary.3dm (440.4 KB)
Contour & Surface Boundary.gh (18.7 KB)
