Offset closed polygon to inside
Dear all,
I’m trying to offset a (convex) quadrilateral to the inside. But for some reasons, two of the four offset points are not where they should be, as can be seen in the image:
What am I missing?
Attached is also the script:
    internal static double[][] PtsFromOffsetRectangle(List<Point3d>plist, double offsetdistance)
        double[][] ptz = new double[4][];
        for (int i = 0; i < 4; i++)
            ptz[i] = new double[2];
            ptz[i][0] = plist[i].X;
            ptz[i][1] = plist[i].Y;
        double[] dblcen = Misc.Centroid(ptz);
        Point3d cen = new Point3d(dblcen[0], dblcen[1], 0);
        PolylineCurve crv = new PolylineCurve(plist);
        Curve[] offsetcr = crv.Offset(cen, Vector3d.ZAxis, offsetdistance,0.1, CurveOffsetCornerStyle.None);
        PolylineCurve offsetpl = offsetcr[0].ToPolyline(0, 0, 0,System.Double.MaxValue, 0, 0.01, 0, 0,true);
        Point3d offsetpt0 = offsetpl.Point(0);
        Point3d offsetpt1 = offsetpl.Point(1);
        Point3d offsetpt2 = offsetpl.Point(2);
        Point3d offsetpt3 = offsetpl.Point(3);
        return new double[][] {
            new double[] {offsetpt0.X, offsetpt0.Y },
            new double[] {offsetpt1.X, offsetpt1.Y },
            new double[] {offsetpt2.X, offsetpt2.Y},
            new double[] {offsetpt3.X, offsetpt3.Y}};
Many thanks,
Christoph
@Christoph1, please post the curve.
_
c.
@clement thanks for coming back. I actually only forgot to close the curve (i.e. plist). Adding the starting point plist.Add(plist[0]) did the trick.
I also noticed, the crv.Offset function really doesn’t like zero tolerance.
Attached the working script:
        plist.Add(plist[0]);
        crv.MakeClosed(0.001);
        Curve[] offsetcr = crv.Offset(cen, Vector3d.ZAxis, offsetdistance,0.001, CurveOffsetCornerStyle.None);
        PolylineCurve offsetpl = offsetcr[0].ToPolyline(0, 0, 0,System.Double.MaxValue, 0, 0.001, 0, 0,true);
