M_Thorez
(Maxime Thorez)
October 21, 2025, 8:02am
1
Hi all,
I’m trying to offset an open polysurface in grasshopper, but the software tells me it is unable to convert a brep into a surface
yet, if I bake the said polysurface and then use _Offsetsurface in regular rhino, it works just fine (see “expected result”)
is there a way to convert a brep in a polysurface in grasshopper (considering all faces are planar, or at least are supposed to be), and if not, how may I proceed otherwise?
thank you in advance
bre-offset-gh.gh (9.1 KB)
offset-brep-rhino.3dm (7.6 MB)
jessesn
(Jessesn Chen)
October 21, 2025, 8:21am
2
Maxime Thorez:
Please try to use GhPython to call OffsetBrep in Rhinocommon achieving it, and for your reference.
bre-offset-gh.gh (26.3 KB)
inno
October 21, 2025, 8:52am
3
the reason why the Brep is still open after the Offset can be found in the center surfaces, and it’s unrelated to the Brep Offset operation:
There’s a problem with the central surfaces, the ones you initially merge, probably the common central vertex does not lie (XY wise) on the polar rotation plane
M_Thorez
(Maxime Thorez)
October 21, 2025, 8:56am
4
Hi
Thank you for your help,
but in my rhino, the Python component is declared as “old”, is it an issue?
M_Thorez
(Maxime Thorez)
October 21, 2025, 8:57am
5
my issue was not the brep being open, but I did notice the gap afterwars
it was due to an imprecision in the defining surfaces and has been fixed since
thank you for your help
jessesn
(Jessesn Chen)
October 21, 2025, 9:05am
6
Yes, you are right, it’s a old GhPython component and It’s not an issue.
