So I have a command that puts a curve into the document with history added to it:
HistoryRecord history = new HistoryRecord(this, History_Version);
…(add some history to historyRecord)
obj = RhinoDoc.ActiveDoc.Objects.AddCurve(_profile, null, history, false);
(background info: this _profile is sitting on another curve, and I am using history so that if the base curve is moved this curve moves with it.)
So then later we re-run this command and edit the shape of this _profile curve, and now want to replace the curve we added above using:
RhinoDoc.ActiveDoc.Objects.Replace(obj, _profile);
This Replace appears to drop the history, I think Rhino even tells you that you are about to break history.
(I do not want to delete and re-add this _profile, as this breaks any history attached to this _profile curve. For example we sweep a surface using this _profile as one of the profiles to sweep. If I delete and add the profile then the history of the sweep is broken.)
So I am looking for something like:
RhinoDoc.ActiveDoc.Objects.Replace(obj, _profile) that keep the history.
or some way to re-add the history back to this replaced object. (either way would work?)
If you need any more info, I could probably make a simple demo plugin, to show the full problem.
Thanks
GordonJ.
